Randomly stop printing
I've a problem with a Jgaurora A5 (not 5s). The printer randomly stop during printing with repetier server. Last original firmware. I attached the log file:
https://drive.google.com/file/d/1cbLy4sSICRJQQc09FrYFCU0zjtJ59nvf/view?usp=sharing
Also check server.log if it stops due to usb disconnect. But undervoltage on pi is the typical reason for this problem.
Is it possible that the display or its wiring could disrupt the communication? I suspected the display because when I operated the printer from the display and R-S, it sometimes stopped reacting either on the display or on the R-S commands.
Edit: On my FLSUN QQ-S I have had no problems like that.
To have a display on the printer is now redundant since I can monitor everything I need from the server via a phone, so I will just keep it disconnected unless I will need to print from an SD card.
2 sides talking over serial can in deed give problems. Especially if one side does not see the changes. So best only to use one of them.
