G28 command broken
Recently printing some models with Repetier host ( V2.1.6), When G28 X Y command is issued, it treats as G28 X0 neglecting Y completely. However, the same file printed with SD card and with Pronterface works like charm, no issue. Initially thought it was buggy firmware, but pronterface printed fine, so I suspect it has to do with Repetier host. Pls, Take look into it.
Sending G28 Y works as G28 Y0, but doesn't home when G28 X Y when given.
Machine used: Monoprice Mp10 Mini
G28 X0 Y0
and will also work well.
Great. Thanks. yes, i changed the syntax.
