PRUSA PAUSE PRINT
I would like to pause a print to clean the hot end, then return to printing where it left off. I understand this needs so G code but I do not know what to write. I also understand that I should put this in the 'Pause' section for G code actions
Hopefully, during the pause, the extruder would be at least 30mm above the bed.
G1 X0 Y180 F12000
30mm above bed is bit of a problem. You need to go up - down is dangerous of course. So you can switch to relative positions and move 30mm up
G91
G1 Z30 F240
G90
but then you need to be sure to be not too high, also I guess firmware might prevent this when it sees going above z max value.
Server will remember start position and go back to it on continue.
I almost always need this early in the print.
So I would add this to the 'Pause'
G1 XO Y180 F1200
G91
G1 Z30 F240
G90
do I have this written correctly?
G1 X0 Y180 F1200
not
G1 XO Y180 F1200
but apart of the type if O instead of 0 it is correct.
could not have done it without you!
Can you still help?
yes I did put it in the "event dependent" > 'run on pause"
I have changed x=250 y=0 - I think this is my right front corner on my MK3S
I changed the F to 12000
