Repetier server and Repetier Informer on Andorid doesn't work anynomore together?
Good moring, I'm Andrea from Italy....since about 10 days Repetier Inofrmer doesn't show up anymore the messages sent from Repetier Server.... I don't know if the problem is on the Server side or Infomer Side....I've reinstalled both of them and created a new group as well but nothing works anymore.
Is this a known issue you're already working on?
Andrea
Andrea
What are you missing - push messages or even no messages in app if you refresh? In latter case recheck if group id is the same in both and if it is enabled in server.
If you still have problems. Make sure you have same group and the send me a PM with group and device id and I check our database if I see anything.
