@pause problem
I've been trying to write a short macro to help me level the bed. The idea is to move the extruder to a specific position, pause to let me take a measurement, I click to continue and then the process repeats a total of four measurements in four different positions.
G1 Z100 X41 Y137 F3000
G1 Z50.4 X41 Y137 F3000
;@pause take measurement
G1 Z100 X162 Y137 F3000
G1 Z50.4 X162 Y137 F3000
G1 Z100 X41 Y260 F3000
G1 Z50.4 X41 Y260 F3000
G1 Z100 X162 Y260 F3000
G1 Z50.4 X162 Y260 F3000
But although the pause dialog box pops up the printer carries on moving. So I let it carry on then clicked continue and it moved to, I think, the position it had been in before the first pause.
If I try:
G28 X0 Y0 ; home X and Y axes
@pause
It definitely carries out the G28, the pause dialog box pops up but even before I hit continue (box stays there) it does the G1. When I click continue it goes back to the position it was in before the @pause, even moving the Z axis back.
I expected the extruder to stay in the position it was before the @pause, and only continue moving after I click continue.
If anyone can tell me what I'm doing wrong then it would be appreciated. I've not posted this as a bug report but I fully expect that I've made a mistake.
  • @pause pauses a print - if you defined a named macro this will not pause. The content is just put into the manual commands queue while @pause affects the print gcode queue only. So if you make it a gcode file that you start like a print it should do the pauses.
    Just make sure there is no move in your pause start/end script that gets send on each pause.
  • Thanks, that clears that up.
    Just one thing I'd like to check:
    ."Just make sure there is no move in your pause start/end script that gets send on each pause."
    I assume you mean in the script for run on pause?
    "You have the possibility to define some G-Code scripts for start, end, run on kill, run on pause and..."
    I will double-check that before I do anything.
  • Yes, that is the script I meant. Normally you would move there to a pause position so you get no filament on print during pause.
  • OK. That makes sense. Thanks for your help.
