Firmware Error Handling
dont know if this question is already discussed here in forum, so sorry if that already answered.
I have some printers running Marlin with Repetier Server. One of them have sporadically thermal runaways. Must change the thermal sensor. But my focus is about firmware error handling by repetier server, if its the case.
Example: If an thermal runaway occurs, is it makeable to react with an action in repetier server - e.g. execute an script if however marlin firmware stopped working?
Repetier Server reports an Firmware stopped message within the UI. But would like to execute a script on this event, can you advice me a little - maybe with response to event with an @execute command?
The other problem is, even if i can get this way to manage the events, repetier server dont seems to log the output from the firmware stopped printer, despite having activated this. Littlebit confused, cause must create an regex for string matching firmware event - i think
Greets
Greets
In printer configuration->g-code->advanced you can define regular expression for a response and set a script to be executed when detected. Can be g-code and server commands like @execute.
The message you mentioned reacts on seeing M999 in response.
