Seeking printer configuration tutorial for Da Vinci 2.0a Duo flash with Repetier-Firmware-0.92
Hello,
I just flashed my printer, I installed Repetier-Host, Repetier-Server, but I'm a bit lost now, I'm not sure how to configure my printer, I did a first try, my print is back In the mailbox, but it lasted 1/1000 of a second. Could you give me the procedure to follow to get started with all this please?
Thank you for your help, Tchicken.
http://dl.free.fr/hb6I8dFRu
http://dl.free.fr/s39jJLDFg
On the configuration of the extruders I also have errors :
http://dl.free.fr/qRlsrgQP8
And on the G-Code I have nothing at all :
http://dl.free.fr/kBC9NuGpe
So when I send an impression to the server, this is what happens :
http://dl.free.fr/sI17WEwsO
Then I have this error message :
http://dl.free.fr/ogbegAYkJ
Voici mon fichier de configuration :
http://dl.free.fr/groEebwCE
Thanks, Tchicken
But that is not the reason it does not print. In your print screenshot I saw you tried printing a 3mf file. Well 3mf is a model file and you need to slice it first using a slicer and then print the generated gcode file. A good free slicer is PrusaSlicer which is also integrated in our Repetier-Host.
Thanks for your help, Thcicken.
