How add more Serial connections to use multiple device at same time (plugin programming)
I'm writing a plugin that sends data to multiple devices at same time (culd be another printer , cnc , laser cutter); my plugin will decide wich kind of data send to every device during the printing job.
The question is how add more Serial connections to have access at the new hardware connected (with Repetier firmware) and be able to send g-code trhougt the new COM ports?I know I quite tricky but the result will be cool.
Thankyou in advance
