Where are the setup and tuning data stored?
Computer died, saved the HD to a USB external box, put up a new machine, installed Repetier Host (V2.1.6) from a download. Now I get to go thru and re-create all of those (about a zillion) tuning settings I had adjusted on the previous setup. Is there a file within the Repetier Host environment that I can copy over from the old setup and pick all of those up without going thru by hand again (including the Cura slicing engine)?
CuraEngine is in HOMDIR/AppData/local/Repetier-Host/CuraEngine and slic3r in HOME/AppData/Roaming/Slic3r or Slic3rPE for PrusaEngine.
