GCodes skipped
Hello,
I just equipped my anet a8 3d printerwith a laserdiode. The hardware works. Did some simple tests ( lines ) and that was successful.
Now I'm trying to make a engraved drawing of the Coderdojo logo.
Now i have two problems.
Problem 1, not severe but a solution would be interesting.
The laser is controlled with the fan output. When generating the repetier GCode there's no automatic generated of an on- or off-code for the laser. In my case that would be M106 S0 or M106 S255 ( or similar ). I now add it each time it before it moves fast G1 F9000 or so ( M106 S0 ) or after it got its command to move slow G1 F400 ( depending on settings of course ) : M106 S125.
Is there a way to have this automatically ?
Problem 2, more severe.
It seems the combination Repetier/Anet with Marlin 2.0 only executes the G1 codes, skipping all arcs ( G2 and G3 ). I would add a picture of the result here if I could.
The code was generated within Inkscape and the Repetier plugin. When looking in online viewers everything is ok.
I add the code here ( without the M106 commands ).
Thanks for looking at it ....
M452
M3 S191
G90
G21
G0 F3000
G0 X67.1381 Y149.7894
G1 F400.000000
G2 X63.2907 Y150.4902 I0.7235 J14.8836
G2 X59.7975 Y152.1552 I4.4756 J13.887
G2 X58.5892 Y153.0369 I7.7662 J11.911
G2 X57.4426 Y154.0714 I9.5654 J11.7555
G2 X56.833 Y154.7127 I12.1264 J12.1367
G2 X56.3447 Y155.2877 I9.2565 J8.3548
G2 X55.4662 Y156.5161 I11.1537 J8.9047
G2 X54.7111 Y157.8483 I12.3712 J7.8926
G2 X53.7282 Y160.4238 I12.4841 J6.2394
G2 X53.2415 Y163.25 I14.5749 J3.9653
G2 X53.2059 Y164.1904 I12.4549 J0.942
G2 X53.2412 Y165.1466 I12.9103 J0.0017
G2 X53.402 Y166.5135 I15.921 J-1.1801
G2 X53.6668 Y167.7797 I13.9199 J-2.2497
G2 X54.8675 Y170.8639 I13.4692 J-3.4679
G2 X56.832 Y173.7064 I13.3716 J-7.1413
G2 X57.434 Y174.348 I9.5577 J-8.3652
G2 X58.1072 Y174.9743 I9.7787 J-9.8345
G2 X61.4789 Y177.1927 I9.8944 J-11.3671
G2 X65.267 Y178.4119 I6.3411 J-13.2072
G2 X70.462 Y178.4027 I2.5718 J-14.5322
G2 X75.2492 Y176.6089 I-2.5402 J-14.0632
G2 X76.7198 Y175.6019 I-7.3684 J-12.3384
G2 X78.0689 Y174.4094 I-9.0216 J-11.5655
G2 X81.6628 Y168.4161 I-10.1713 J-10.1735
G2 X82.0208 Y161.3958 I-13.9277 J-4.2296
G2 X80.2957 Y156.8704 I-13.9427 J2.7236
G2 X77.1203 Y153.1365 I-12.5147 J7.4254
G2 X73.6228 Y150.9716 I-9.2888 J11.0989
G2 X69.6866 Y149.8907 I-5.7034 J13.0624
G2 X68.3867 Y149.7839 I-1.913 J15.3115
G2 X67.1381 Y149.7894 I-0.562 J14.1329
G1 X67.1381 Y149.7894
G0 F3000
G0 X63.6456 Y151.0518
G1 F400.000000
G2 X63.0918 Y151.4675 I3.9797 J5.8785
G2 X62.5477 Y151.963 I5.1196 J6.1689
G2 X61.2578 Y153.6959 I5.231 J5.2401
G2 X60.5344 Y155.7062 I6.379 J3.4309
G2 X60.3969 Y157.331 I7.0906 J1.4181
G2 X60.6274 Y158.9599 I7.3569 J-0.2103
G2 X62.0401 Y161.7418 I7.0055 J-1.808
G2 X64.5304 Y163.7157 I5.8012 J-4.7609
G2 X65.7371 Y164.1842 I3.3029 J-6.7185
G2 X67.028 Y164.4441 I2.1692 J-7.4375
G2 X67.2571 Y164.4634 I0.4398 J-3.8672
G2 X67.7985 Y164.4859 I1.174 J-21.6495
G3 X68.7564 Y164.5525 I-0.3422 J11.8502
G3 X69.4156 Y164.6644 I-0.6303 J5.7125
G3 X71.217 Y165.352 I-1.5668 J6.8074
G3 X72.7533 Y166.5013 I-3.335 J6.0597
G3 X73.1063 Y166.8778 I-5.0203 J5.0607
G3 X73.4228 Y167.2693 I-5.1121 J4.4563
G3 X74.7199 Y170.5639 I-5.3585 J4.0123
G3 X74.1552 Y174.0609 I-6.6617 J0.7184
G3 X71.978 Y176.7287 I-6.1667 J-2.8103
G3 X68.7129 Y178.0243 I-4.1517 J-5.7009
G3 X67.6501 Y178.0791 I-0.899 J-7.0959
G3 X66.0798 Y177.9639 I0.3583 J-15.6398
G3 X61.0572 Y176.3476 I1.7423 J-14.0265
G3 X56.9738 Y173.0002 I6.7749 J-12.4288
G3 X55.5131 Y170.8783 I10.5679 J-8.8383
G3 X54.4796 Y168.5333 I11.9046 J-6.6473
G3 X53.8378 Y165.4886 I13.0582 J-4.3421
G3 X53.8974 Y162.3865 I13.621 J-1.2899
G3 X54.1268 Y161.1298 I13.2795 J1.7744
G3 X54.4795 Y159.8804 I13.4813 J3.1312
G3 X55.5938 Y157.3994 I12.9119 J4.3084
G3 X57.2144 Y155.1281 I12.4164 J7.1455
G3 X57.8163 Y154.4843 I9.6219 J8.3929
G3 X58.4852 Y153.8597 I9.7251 J9.7431
G3 X60.8784 Y152.1658 I9.4651 J10.8357
G3 X63.5567 Y150.9973 I7.0239 J12.4447
G3 X63.8364 Y150.9094 I9.309 J29.1348
G1 X63.8488 Y150.9069
G1 X63.8499 Y150.9099
G3 X63.6456 Y151.0518 I-6.0057 J-8.4288
G1 X63.6456 Y151.0518
G0 F3000
G0 X69.8758 Y153.2599
G1 F400.000000
G3 X70.0364 Y153.342 I-0.12 J0.4326
G3 X70.1474 Y153.4772 I-0.2642 J0.3301
G1 X70.1946 Y153.568
G1 X70.1946 Y154.7991
G1 X70.1946 Y156.0303
G1 X70.148 Y156.1221
G3 X69.9726 Y156.3032 I-0.3802 J-0.1928
G3 X69.7266 Y156.3529 I-0.203 J-0.3706
G3 X69.5261 Y156.2794 I0.044 J-0.4298
G3 X69.376 Y156.1126 I0.2703 J-0.3941
G1 X69.3563 Y156.0406
G3 X69.3347 Y155.0839 I27.1264 J-1.0912
G1 X69.3299 Y154.1229
G1 X68.8986 Y154.1229
G1 X68.4673 Y154.1229
G1 X68.4673 Y157.1116
G1 X68.4673 Y160.1004
G1 X67.339 Y160.1004
G3 X66.2121 Y160.0912 I0. J-69.1232
G1 X66.1435 Y160.0803
G1 X66.0809 Y160.0519
G3 X65.9946 Y159.9867 I0.3367 J-0.5359
G3 X65.8586 Y159.6048 I0.2845 J-0.3164
G3 X66.1051 Y159.2766 I0.431 J0.0671
G1 X66.1937 Y159.2547
G3 X66.8968 Y159.2369 I0.7071 J14.1035
G1 X67.6037 Y159.2368
G1 X67.6037 Y156.681
G1 X67.6037 Y154.1252
G1 X66.8798 Y154.1192
G3 X66.1134 Y154.0669 I0.0568 J-6.4784
G1 X65.9693 Y154.0017
G3 X65.873 Y153.8692 I0.246 J-0.2801
G3 X65.8353 Y153.691 I0.4232 J-0.1825
G3 X65.8481 Y153.576 I0.4793 J-0.0052
G3 X65.8844 Y153.4818 I0.3586 J0.0844
G3 X65.9411 Y153.3964 I0.5615 J0.3108
G3 X65.9945 Y153.3415 I0.2825 J0.2217
G1 X66.1277 Y153.2899
G3 X68.0101 Y153.2435 I1.9064 J39.2097
G3 X69.8124 Y153.2509 I0.1271 J189.7125
G1 X69.8758 Y153.2597
G1 X69.8758 Y153.2599
G0 F3000
G0 X65.9274 Y168.992
G1 F400.000000
G2 X65.8533 Y169.0129 I0.0834 J0.4367
G2 X65.7304 Y169.0663 I0.4973 J1.3131
G2 X65.5248 Y169.2122 I0.3509 J0.7124
G2 X65.3635 Y169.4266 I0.6306 J0.6419
G2 X65.3125 Y169.6158 I0.3761 J0.203
G2 X65.2673 Y172.4036 I86.491 J2.7974
G2 X65.2758 Y175.0625 I398.9881 J0.0443
G2 X65.2853 Y175.1638 I0.5871 J-0.0038
G2 X65.3632 Y175.3845 I0.7285 J-0.1331
G2 X65.5185 Y175.5925 I0.7993 J-0.4348
G2 X65.6364 Y175.698 I0.9936 J-0.9916
G2 X65.7169 Y175.7509 I0.3247 J-0.4068
G2 X65.9115 Y175.8051 I0.2206 J-0.4152
G2 X67.4676 Y175.848 I1.5474 J-27.9071
G2 X68.9321 Y175.8392 I-0.0375 J-128.7587
G2 X69.0073 Y175.8305 I-0.0042 J-0.3641
G2 X69.4173 Y175.5972 I-0.1846 J-0.8012
G2 X69.6354 Y175.173 I-0.6082 J-0.5809
G2 X69.8949 Y172.4109 I-14.568 J-2.7621
G2 X69.6354 Y169.649 I-14.8252 J-0.
G2 X69.4077 Y169.2185 I-0.8122 J0.154
G2 X68.9772 Y168.9908 I-0.5846 J0.5846
G2 X67.4388 Y168.8471 I-1.5294 J8.0642
G2 X65.9273 Y168.9918 I0.0088 J8.056
G1 X65.9274 Y168.992
G0 F3000
G0 X68.7891 Y172.411
G1 F400.000000
G1 X68.7891 Y174.9679
G1 X67.4683 Y174.9679
G1 X66.1475 Y174.9679
G1 X66.1475 Y172.411
G1 X66.1475 Y169.854
G1 X67.4683 Y169.854
G1 X68.7891 Y169.854
G1 X68.7891 Y172.411
G0 F3000
G0 X92.7836 Y154.293
G1 F400.000000
G2 X90.8063 Y154.9648 I0.2612 J4.0143
G2 X89.7719 Y156.3099 I1.478 J2.207
G2 X89.6701 Y156.6642 I3.4454 J1.1818
G2 X89.5888 Y157.0948 I5.0109 J1.169
G2 X89.5735 Y157.299 I1.4613 J0.2119
G2 X89.5535 Y163.8935 I1531.1737 J7.9517
G2 X89.5566 Y170.4887 I2444.6181 J2.1525
G2 X89.5661 Y170.7388 I3.439 J-0.0062
G2 X89.8913 Y172.1021 I4.3808 J-0.3243
G2 X90.5087 Y173.0037 I2.4652 J-1.0259
G2 X91.585 Y173.6378 I1.8805 J-1.9616
G2 X93.3339 Y173.879 I1.6061 J-5.1841
G2 X94.7301 Y173.6096 I-0.1142 J-4.3437
G2 X95.6465 Y173.0218 I-0.8856 J-2.3889
G2 X96.1579 Y172.288 I-1.8022 J-1.8012
G2 X96.4947 Y171.1833 I-3.8572 J-1.7796
G2 X96.516 Y170.9449 I-1.6772 J-0.2699
G2 X96.5385 Y168.8169 I-134.2136 J-2.4849
G1 X96.5442 Y166.6875
G1 X95.2909 Y166.6875
G1 X94.0377 Y166.6875
G1 X94.0329 Y168.7237
G1 X94.0281 Y170.76
G1 X93.9901 Y170.894
G3 X93.7602 Y171.2016 I-0.5164 J-0.1463
G3 X93.2579 Y171.3561 I-0.5362 J-0.8497
G3 X92.6157 Y171.1891 I-0.0395 J-1.1667
G3 X92.2973 Y170.7769 I0.3713 J-0.6159
G3 X92.282 Y170.6731 I0.3582 J-0.1057
G3 X92.2629 Y164.1306 I1452.7462 J-7.528
G3 X92.299 Y157.4673 I546.3449 J-0.3721
G3 X92.3423 Y157.2369 I0.6762 J0.0078
G3 X92.5169 Y156.9716 I0.6739 J0.2536
G3 X92.7827 Y156.8131 I0.474 J0.4926
G3 X93.0872 Y156.758 I0.3623 J1.1326
G3 X93.4546 Y156.7803 I0.0819 J1.6858
G3 X93.6771 Y156.8475 I-0.1616 J0.938
G3 X93.814 Y156.939 I-0.1919 J0.435
G3 X93.9046 Y157.0598 I-0.3188 J0.3335
G3 X93.9961 Y157.2894 I-1.1001 J0.5716
G3 X94.0128 Y157.4016 I-0.4137 J0.1187
G3 X94.0327 Y159.7151 I-178.9885 J2.6974
G1 X94.0377 Y162.0308
G1 X95.2903 Y162.0308
G1 X96.543 Y162.0308
G1 X96.5428 Y159.7405
G2 X96.5139 Y157.2627 I-106.8647 J0.0078
G2 X96.4754 Y156.8402 I-3.1316 J0.0729
G2 X95.5824 Y155.1362 I-2.984 J0.4778
G2 X93.8441 Y154.3184 I-2.085 J2.1755
G2 X93.3211 Y154.2819 I-0.6622 J5.7207
G2 X92.7838 Y154.2929 I-0.1454 J6.0154
G1 X92.7836 Y154.293
G0 F3000
G0 X100.9478 Y154.2924
G1 F400.000000
G2 X99.3552 Y154.7845 I0.2508 J3.6351
G2 X98.4382 Y155.7644 I1.1947 J2.037
G2 X98.2639 Y156.2097 I2.3524 J1.1776
G2 X98.1312 Y156.8237 I4.3601 J1.2637
G2 X97.7731 Y161.802 I34.4214 J4.9783
G2 X98.1312 Y166.7805 I34.7826 J0.
G2 X98.3271 Y167.5727 I4.0913 J-0.5916
G2 X98.6212 Y168.16 I2.5238 J-0.8966
G2 X99.65 Y169.0059 I1.9041 J-1.2672
G2 X101.4704 Y169.3404 I1.6909 J-4.0814
G2 X102.7151 Y169.1188 I-0.1269 J-4.3184
G2 X103.5802 Y168.634 I-0.8437 J-2.5201
G2 X104.0872 Y168.0272 I-1.4484 J-1.7253
G2 X104.4232 Y167.1602 I-2.7041 J-1.5467
G2 X104.4796 Y166.6912 I-2.303 J-0.5149
G2 X104.5269 Y161.8275 I-250.097 J-4.8636
G2 X104.4875 Y156.9619 I-300.2673 J0.
G2 X104.4413 Y156.5315 I-2.39 J0.0387
G2 X104.1595 Y155.7237 I-3.0576 J0.6136
G2 X103.7148 Y155.1127 I-2.166 J1.1091
G2 X103.3787 Y154.8297 I-1.8144 J1.8134
G2 X103.0086 Y154.6147 I-1.4036 J1.9903
G2 X102.4877 Y154.4244 I-1.3387 J2.8567
G2 X101.8768 Y154.3109 I-1.0267 J3.8254
G2 X101.4033 Y154.2813 I-0.5847 J5.541
G2 X100.9478 Y154.2924 I-0.1024 J5.1275
G1 X100.9478 Y154.2924
G0 F3000
G0 X101.7128 Y156.6965
G1 F400.000000
G3 X101.9184 Y156.8392 I-0.1254 J0.4002
G3 X102.0492 Y157.129 I-0.5342 J0.4155
G3 X102.4872 Y161.8021 I-24.7124 J4.6731
G3 X102.0492 Y166.4753 I-25.1504 J-0.
G3 X101.8478 Y166.794 I-0.5035 J-0.0952
G3 X101.3942 Y166.9534 I-0.4913 J-0.6731
G3 X101.0385 Y166.9359 I-0.0858 J-1.8876
G3 X100.831 Y166.8722 I0.1006 J-0.6968
G3 X100.7018 Y166.7673 I0.1605 J-0.3298
G3 X100.602 Y166.5773 I0.4821 J-0.3744
G1 X100.5645 Y166.4588
G1 X100.5645 Y161.7852
G3 X100.5794 Y157.1139 I732.3554 J0.
G3 X100.5953 Y157.01 I0.3624 J0.0023
G3 X100.7459 Y156.8015 I0.3787 J0.115
G3 X101.0979 Y156.6555 I0.5008 J0.7101
G1 X101.1405 Y156.6518
G3 X101.3688 Y156.6545 I0.043 J5.829
G3 X101.5956 Y156.6715 I-0.0718 J2.4848
G3 X101.7128 Y156.6967 I-0.0786 J0.6493
G1 X101.7128 Y156.6965
G0 F3000
G0 X108.2946 Y154.3451
G1 F400.000000
G2 X107.4486 Y154.5811 I0.3196 J2.7799
G2 X106.8407 Y155.0112 I0.8379 J1.8288
G2 X106.4357 Y155.6105 I1.4963 J1.4476
G2 X106.1491 Y156.5613 I3.5837 J1.5989
G2 X106.1337 Y156.7403 I1.1174 J0.1868
G2 X106.1135 Y161.7259 I866.4129 J5.9889
G2 X106.1173 Y166.7124 I1350.973 J1.472
G2 X106.1273 Y166.9414 I2.7845 J-0.0072
G2 X106.7147 Y168.4983 I3.0483 J-0.2608
G2 X107.8286 Y169.2447 I1.5981 J-1.1804
G2 X108.1993 Y169.3102 I0.643 J-2.5574
G2 X108.7179 Y169.3371 I0.5198 J-5.0071
G2 X109.0976 Y169.3245 I0.0009 J-5.6805
G2 X109.2894 Y169.2987 I-0.0969 J-1.4497
G2 X109.672 Y169.1893 I-0.4981 J-2.4655
G2 X110.1953 Y168.9601 I-1.8136 J-4.852
G1 X110.2017 Y168.9638
G3 X110.208 Y171.3173 I-437.9126 J2.3535
G1 X110.208 Y173.6809
G1 X111.4441 Y173.6809
G1 X112.6803 Y173.6809
G1 X112.6803 Y164.0797
G1 X112.6803 Y154.4785
G1 X111.5819 Y154.4785
G1 X110.4835 Y154.4785
G1 X110.4727 Y154.5571
G2 X110.4648 Y154.6359 I1.0514 J0.146
G2 X110.4619 Y154.7254 I1.4105 J0.0896
G3 X110.4552 Y154.8113 I-0.5522 J-0.
G1 X110.4459 Y154.825
G1 X110.43 Y154.8253
G3 X110.3147 Y154.757 I0.5192 J-1.0087
G2 X109.627 Y154.4473 I-1.2417 J1.8383
G2 X108.6524 Y154.3283 I-0.9388 J3.6401
G2 X108.4217 Y154.3349 I0.0441 J5.598
G2 X108.2944 Y154.3451 I0.101 J2.0539
G1 X108.2946 Y154.3451
G0 F3000
G0 X109.5213 Y156.7903
G1 F400.000000
G3 X109.8756 Y156.9636 I-0.2498 J0.9597
G3 X110.146 Y157.27 I-0.6493 J0.8455
G1 X110.2081 Y157.3759
G1 X110.2081 Y161.8728
G1 X110.2081 Y166.3697
G1 X110.1453 Y166.4735
G3 X109.8689 Y166.7799 I-0.9354 J-0.566
G3 X109.5126 Y166.9515 I-0.6057 J-0.8017
G3 X109.1777 Y166.9888 I-0.3 J-1.171
G3 X108.8838 Y166.9334 I0.0275 J-0.9529
G3 X108.748 Y166.8424 I0.1127 J-0.315
G3 X108.6592 Y166.6842 I0.3063 J-0.276
G3 X108.627 Y166.4722 I0.7402 J-0.2207
G3 X108.6034 Y161.709 I381.0613 J-4.2742
G3 X108.623 Y157.2488 I702.2934 J0.8538
G3 X108.6377 Y157.1309 I0.5107 J0.0039
G3 X108.8168 Y156.8861 I0.3862 J0.0947
G3 X109.2351 Y156.7663 I0.4264 J0.6989
G3 X109.421 Y156.7735 I0.0168 J1.9917
G3 X109.5214 Y156.7903 I-0.0531 J0.6229
G1 X109.5213 Y156.7903
G0 F3000
G0 X116.9898 Y154.2857
G1 F400.000000
G2 X116.0491 Y154.4537 I0.2509 J4.122
G2 X115.3588 Y154.7772 I0.7586 J2.5172
G2 X115.0099 Y155.0624 I1.2248 J1.8546
G2 X114.7242 Y155.4136 I1.5882 J1.5837
G2 X114.416 Y156.0467 I2.2909 J1.5068
G2 X114.229 Y156.8867 I3.8827 J1.3053
G2 X114.2157 Y157.1123 I2.0501 J0.234
G2 X114.2086 Y161.8953 I917.7737 J3.7539
G2 X114.2635 Y166.7686 I240.3517 J-0.272
G2 X114.3228 Y167.2247 I2.1356 J-0.0457
G2 X115.2098 Y168.6493 I2.5946 J-0.6271
G2 X116.8528 Y169.3306 I1.9185 J-2.305
G2 X117.3832 Y169.3482 I0.4153 J-4.4988
G2 X117.9125 Y169.3037 I-0.1158 J-4.5412
G2 X119.4905 Y168.5223 I-0.4013 J-2.7944
G2 X120.3162 Y166.9404 I-2.0326 J-2.0673
G2 X120.3561 Y166.5174 I-2.8353 J-0.4812
G2 X120.3817 Y163.7071 I-125.8277 J-2.5488
G1 X120.3767 Y161.2603
G1 X118.4754 Y161.2563
G1 X116.5741 Y161.2523
G1 X116.5801 Y159.2246
G3 X116.6237 Y157.1362 I57.6651 J0.1603
G3 X116.6686 Y156.9413 I0.5369 J0.021
G3 X116.8384 Y156.7516 I0.3762 J0.166
G3 X117.1681 Y156.6515 I0.3776 J0.6508
G3 X117.6444 Y156.7291 I0.069 J1.0781
G3 X117.8724 Y156.9383 I-0.1675 J0.4114
G3 X117.9277 Y157.1391 I-0.4575 J0.2339
G3 X117.9764 Y158.5473 I-23.498 J1.5184
G1 X117.9824 Y159.8639
G1 X119.1851 Y159.8639
G1 X120.3878 Y159.8639
G1 X120.3808 Y158.4457
G2 X120.3615 Y157.0285 I-81.5227 J0.4015
G2 X120.345 Y156.8336 I-1.5742 J0.0351
G2 X120.1452 Y156.0228 I-4.3566 J0.6434
G2 X119.8589 Y155.4443 I-2.4834 J0.8687
G2 X119.5652 Y155.0827 I-1.9506 J1.2849
G2 X119.217 Y154.7983 I-1.5425 J1.5328
G2 X118.5748 Y154.4836 I-1.5646 J2.3804
G2 X117.7946 Y154.3116 I-1.1507 J3.3626
G2 X117.3462 Y154.2811 I-0.6432 J6.1467
G2 X116.9903 Y154.2863 I-0.1217 J3.8603
G1 X116.9898 Y154.2857
G0 F3000
G0 X121.8243 Y161.8022
G1 F400.000000
G1 X121.8243 Y169.1259
G1 X122.9143 Y169.1259
G1 X124.0043 Y169.1259
G1 X124.0257 Y168.9608
G3 X124.0494 Y168.7965 I5.5177 J0.711
G1 X124.0538 Y168.7838
G1 X124.0634 Y168.7812
G3 X124.1997 Y168.867 I-1.0571 J1.8315
G2 X124.4521 Y169.0151 I1.2029 J-1.76
G2 X124.7199 Y169.1261 I0.9334 J-1.8737
G2 X125.3764 Y169.2578 I0.8496 J-2.5338
G2 X125.9849 Y169.2177 I0.1601 J-2.2099
G2 X126.3828 Y169.1079 I-0.6422 J-3.1035
G1 X126.4851 Y169.0438
G1 X126.4915 Y169.0285
G2 X126.4941 Y167.6739 I-147.5266 J-0.9593
G1 X126.4901 Y166.3169
G1 X126.1807 Y166.5179
G3 X125.8675 Y166.7108 I-4.1692 J-6.419
G3 X125.7913 Y166.745 I-0.1988 J-0.3408
G3 X125.3923 Y166.8109 I-0.4145 J-1.2674
G3 X124.9599 Y166.755 I-0.0181 J-1.5587
G3 X124.6227 Y166.5973 I0.2991 J-1.0791
G3 X124.38 Y166.3545 I0.5413 J-0.784
G1 X124.3311 Y166.2837
G1 X124.3311 Y160.3813
G1 X124.3311 Y154.4788
G1 X123.078 Y154.4788
G1 X121.8249 Y154.4788
G1 X121.8243 Y161.8022
G0 F3000
G0 X117.976 Y164.7697
G1 F400.000000
G3 X117.9568 Y166.3555 I-92.3896 J-0.3242
G3 X117.9415 Y166.4634 I-0.4536 J-0.0094
G3 X117.7078 Y166.7917 I-0.5593 J-0.1507
G3 X117.2523 Y166.9319 I-0.4554 J-0.67
G3 X116.9341 Y166.8837 I0.0001 J-1.0754
G3 X116.7677 Y166.7818 I0.1171 J-0.378
G3 X116.6647 Y166.624 I0.3504 J-0.3413
G3 X116.5924 Y166.3487 I1.0346 J-0.4187
G3 X116.5832 Y166.2212 I1.0142 J-0.1376
G3 X116.5754 Y164.702 I159.3941 J-1.5735
G1 X116.5749 Y163.1822
G1 X117.2784 Y163.1822
G1 X117.9818 Y163.1822
G1 X117.976 Y164.7697
G0 F3000
G0 X127.7171 Y164.0795
G1 F400.000000
G1 X127.7171 Y173.6824
G1 X129.7702 Y173.6764
G2 X131.8221 Y173.6545 I-0.401 J-133.7138
G2 X132.0446 Y173.6346 I-0.0289 J-1.5775
G2 X132.8991 Y173.4108 I-0.7543 J-4.6248
G2 X133.5167 Y173.0965 I-0.9909 J-2.7108
G2 X134.3402 Y172.2206 I-1.5007 J-2.2358
G2 X134.8416 Y170.8325 I-3.503 J-2.0499
G2 X134.8564 Y170.6569 I-1.099 J-0.1814
G2 X134.8762 Y164.2149 I-1491.3962 J-7.7905
G2 X134.8726 Y157.7721 I-2281.4278 J-1.9435
G2 X134.8628 Y157.5347 I-3.0288 J0.006
G2 X134.5735 Y156.3012 I-4.2381 J0.3431
G2 X134.0321 Y155.4544 I-2.4841 J0.9918
G2 X133.2265 Y154.8808 I-1.8613 J1.7615
G2 X131.9588 Y154.5172 I-1.8768 J4.1518
G2 X131.7548 Y154.5019 I-0.2307 J1.7108
G2 X129.7363 Y154.483 I-2.5755 J167.0316
G1 X127.717 Y154.476
G1 X127.7171 Y164.0795
G0 F3000
G0 X131.5918 Y156.9935
G1 F400.000000
G3 X131.9457 Y157.1954 I-0.1652 J0.7007
G3 X132.1671 Y157.5922 I-0.6454 J0.6201
G3 X132.1818 Y157.7062 I-0.4498 J0.116
G3 X132.196 Y164.0544 I-1420.109 J6.3482
G3 X132.1809 Y170.4024 I-1333.3397 J-0.
G3 X132.1658 Y170.5144 I-0.4387 J-0.0021
G3 X131.997 Y170.8681 I-1.0697 J-0.2933
G3 X131.7747 Y171.0591 I-0.504 J-0.362
G3 X131.573 Y171.1199 I-0.2698 J-0.5294
G3 X130.9217 Y171.1576 I-0.6552 J-5.6716
G1 X130.3926 Y171.1579
G1 X130.3926 Y164.0628
G1 X130.3926 Y156.9678
G1 X130.9387 Y156.968
G3 X131.4836 Y156.9789 I-0.0066 J14.0666
G3 X131.5918 Y156.9935 I-0.0225 J0.5722
G1 X131.5918 Y156.9935
G0 F3000
G0 X139.3214 Y154.2934
G1 F400.000000
G2 X137.438 Y155.0496 I0.2064 J3.2375
G2 X136.5228 Y156.6505 I1.7252 J2.0483
G2 X136.4851 Y157.0689 I2.6595 J0.4508
G2 X136.4587 Y161.9969 I370.6499 J4.4463
G2 X136.5111 Y166.7153 I242.5853 J-0.3354
G2 X136.5669 Y167.1771 I2.3461 J-0.0489
G2 X137.0182 Y168.2012 I2.8138 J-0.6286
G2 X137.7755 Y168.9048 I2.0158 J-1.4102
G2 X138.2752 Y169.134 I1.3168 J-2.2117
G2 X138.9513 Y169.2984 I1.3084 J-3.9088
G2 X139.6442 Y169.3538 I0.7185 J-4.6289
G2 X140.3399 Y169.3064 I0.0259 J-4.7538
G2 X141.3913 Y168.9903 I-0.5237 J-3.6484
G2 X142.1142 Y168.4678 I-1.0399 J-2.2001
G2 X142.56 Y167.803 I-1.7151 J-1.632
G2 X142.8504 Y166.8233 I-3.5223 J-1.5768
G2 X142.8662 Y166.6274 I-1.3039 J-0.2039
G2 X142.8809 Y161.8025 I-792.9698 J-4.8249
G2 X142.8659 Y156.9776 I-777.7295 J0.
G2 X142.8502 Y156.7818 I-1.3295 J0.0082
G2 X142.5508 Y155.8001 I-3.6448 J0.575
G2 X142.0771 Y155.1204 I-2.1794 J1.0142
G2 X141.2562 Y154.5778 I-1.717 J1.705
G2 X140.0022 Y154.2932 I-1.5303 J3.8382
G2 X139.6748 Y154.2824 I-0.3242 J4.8486
G2 X139.3214 Y154.2937 I0.0037 J5.6192
G1 X139.3214 Y154.2934
G0 F3000
G0 X139.9599 Y156.6698
G1 F400.000000
G3 X140.1861 Y156.7395 I-0.1709 J0.9574
G1 X140.2889 Y156.8169
G3 X140.3591 Y156.9383 I-0.3096 J0.2602
G3 X140.417 Y157.168 I-1.0783 J0.3939
G3 X140.7638 Y161.9571 I-33.2581 J4.8157
G3 X140.415 Y166.4372 I-28.6527 J0.0226
G3 X140.3086 Y166.7332 I-0.8179 J-0.1268
G3 X140.1561 Y166.8728 I-0.3075 J-0.1827
G3 X139.9448 Y166.9371 I-0.3139 J-0.653
G3 X139.5904 Y166.9536 I-0.264 J-1.8475
G3 X139.1508 Y166.8104 I0.0424 J-0.8763
G3 X138.9482 Y166.5313 I0.2682 J-0.4079
G3 X138.9332 Y166.423 I0.4075 J-0.1114
G3 X138.9137 Y161.9038 I719.8685 J-5.3738
G3 X138.9167 Y157.383 I1122.6196 J-1.5069
G3 X138.9255 Y157.2217 I1.5659 J0.0042
G3 X139.0836 Y156.8424 I0.7184 J0.0769
G3 X139.3741 Y156.6708 I0.3775 J0.3074
G3 X139.6671 Y156.6441 I0.296 J1.631
G3 X139.9595 Y156.6698 I0.003 J1.6466
G1 X139.9599 Y156.6698
G0 F3000
G0 X143.2456 Y151.3477
G1 F400.000000
G2 X142.936 Y151.3857 I0.2215 J3.0918
G2 X142.5422 Y151.47 I0.8895 J5.1141
G1 X142.3898 Y151.5089
G1 X142.3858 Y152.6805
G2 X142.3854 Y153.8486 I215.0021 J0.6673
G1 X142.3888 Y153.852
G1 X142.396 Y153.8512
G2 X142.6985 Y153.7774 I-12.4459 J-51.708
G3 X143.6121 Y153.6464 I1.1113 J4.4967
G3 X144.0685 Y153.7189 I0.0495 J1.1598
G3 X144.299 Y153.8937 I-0.1768 J0.4724
G3 X144.4751 Y154.2754 I-0.8601 J0.6285
G3 X144.4906 Y154.4042 I-0.551 J0.1314
G3 X144.5104 Y161.798 I-1846.1731 J8.6541
G1 X144.5154 Y169.1937
G1 X145.76 Y169.1937
G1 X147.0045 Y169.1937
G1 X146.9995 Y161.6287
G2 X146.9466 Y153.9774 I-606.2086 J0.363
G2 X146.8929 Y153.5187 I-2.2364 J0.0296
G2 X146.3067 Y152.3267 I-2.7678 J0.6208
G2 X145.2937 Y151.5942 I-1.9321 J1.6055
G2 X144.4298 Y151.3762 I-1.2826 J3.2625
G2 X143.2455 Y151.3478 I-0.7404 J6.1541
G1 X143.2456 Y151.3477
G0 F3000
G0 X151.1402 Y154.3866
G1 F400.000000
G2 X149.9805 Y154.7258 I0.4453 J3.675
G2 X149.2371 Y155.3023 I0.9729 J2.0219
G2 X148.8276 Y155.9813 I1.9367 J1.631
G2 X148.575 Y156.9338 I3.6242 J1.4707
G2 X148.5639 Y157.0954 I1.2458 J0.167
G2 X148.5535 Y161.8953 I1110.9492 J4.7999
G1 X148.5535 Y166.6959
G1 X148.5916 Y166.9329
G2 X148.635 Y167.1689 I5.3851 J-0.8673
G2 X148.6804 Y167.3624 I3.5937 J-0.7422
G2 X149.3969 Y168.5899 I2.5708 J-0.6776
G2 X150.6644 Y169.2935 I1.9296 J-1.9824
G2 X151.1209 Y169.3727 I0.7928 J-3.2156
G2 X151.754 Y169.4048 I0.6305 J-6.1757
G2 X152.4031 Y169.3708 I-0.0027 J-6.2605
G2 X152.8703 Y169.2879 I-0.347 J-3.3143
G2 X154.1366 Y168.5697 I-0.6686 J-2.6543
G2 X154.8534 Y167.306 I-1.927 J-1.9281
G2 X154.917 Y166.8372 I-2.0617 J-0.5182
G2 X154.9757 Y162.0392 I-218.6305 J-5.0767
G2 X154.9726 Y157.3998 I-1225.0905 J-1.485
G2 X154.9627 Y157.1455 I-3.527 J0.0091
G2 X154.1387 Y155.2838 I-3.022 J0.2245
G2 X152.343 Y154.3852 I-2.1382 J2.0294
G2 X151.737 Y154.3503 I-0.5994 J5.1239
G2 X151.1402 Y154.3862 I0.0065 J5.0813
G1 X151.1402 Y154.3866
G0 F3000
G0 X151.9799 Y156.7313
G1 F400.000000
G3 X152.33 Y156.9057 I-0.0734 J0.5859
G3 X152.5066 Y157.2733 I-0.4605 J0.4475
G3 X152.7994 Y161.9505 I-37.395 J4.6887
G3 X152.5071 Y166.4651 I-34.8531 J0.0106
G3 X152.2818 Y166.8519 I-0.5721 J-0.0743
G3 X151.7624 Y167.0255 I-0.5195 J-0.6904
G3 X151.3053 Y166.9537 I-0. J-1.4916
G3 X151.1258 Y166.8206 I0.1067 J-0.3315
G3 X151.0871 Y166.7521 I0.3546 J-0.2459
G3 X151.0447 Y166.6409 I0.9027 J-0.4072
G1 X151.0089 Y166.5265
G1 X151.0039 Y161.9545
G3 X151.008 Y157.3831 I1070.5069 J-1.3281
G3 X151.0174 Y157.2412 I1.1262 J0.0034
G3 X151.0851 Y156.9811 I1.0707 J0.1398
G3 X151.1696 Y156.8596 I0.3037 J0.1211
G3 X151.4191 Y156.7403 I0.3254 J0.3602
G3 X151.9798 Y156.7313 I0.3123 J1.9717
G1 X151.9799 Y156.7313
G0 F3000
G0 X144.5149 Y171.9538
G1 F400.000000
G1 X144.5149 Y173.7487
G1 X145.7595 Y173.7487
G1 X147.0041 Y173.7487
G1 X147.0041 Y171.9538
G1 X147.0041 Y170.1588
G1 X145.7595 Y170.1588
G1 X144.5149 Y170.1588
G1 X144.5149 Y171.9538
G0 F3000
G91
G90
M5 S0
G0 X0 Y0
M18
  • Further research on first problem shows me I have to use M450, M451 and M452 to switch between the laser and 3D printer. What is happening then? Does it execute the M106 commands then ?  When speed changes ? On what limits ?
  • Is arc support enabled in your marlin firmware in configuration_adv.h
    // G2/G3 Arc Support
    #define ARC_SUPPORT                 // Disable this feature to save ~3226 bytes
  • @MartinH Thanks, I've seen this option was indeed disabled. I'll try it out this evening ( couldn't check it out yesterday because of flat battery of PC and forgot uploader at work :( ). Hopefully it will still fit on the board after compiling
  • @MartinH ; It worked but another problem appeared now. Al G1 and G3 codes go ful speed, all G2 codes go slow, resulting in the first file in the google drive
    The code i use ( with speed and power ) You find there too.
    There's also an axample of the transit G2 G3 as seen in the onine NCViwer.
    http://https//drive.google.com/open?id=1wNcr_coyi6J8dm9gKvhMexWD8FBNmkxw
