Install problem download failed
Is there anyone meet the same problem? I am able to install repetier host on my other computer but not this one. My internet is good. I could not figure out what is the problem.
It shows "download failed: a connection with the server cannot be established. check your connection and retry to try......
  • Can't say why some have problems with internal download. Uncheck installing Repetier-Server which is what is getting downloaded. Then installation would work. If you want repetier-server download it separately from https://www.repetier-server.com and install it.
