No need to wait 45 hours. It should immediately start downloading files and you see the files and data counter increase. If it does not happen something is wrong.
Now I can not say much since it works for me. So first try again or try again with only parts of the backup selected. I see first step analysing the data worked as it knows already you want to backup 14309 files.
What combination of server os and monitor os are you running?
@Yuriy ;What directory did you use as backup target? It must be writeable by your user. If not that might break the process. Just tested a backup raspberry->W10 and it worked. So main question is what is different in your case preventing it.
