[Delta] Individual steps per mm settings for X, Y and Z-axis
I'm setting up a delta printer. I want to calibrate the steps per mm options but unfortunately in delta mode only the ZAXIS_STEPS_PER_MM option is used.
I think this behaviour should be changed to gain a better printing quality.
The math uses the unit mm, I assume. Z-axis movement means the same amount of mm for each tower but each tower could have a different steps per mm ratio. At least that's the way I would do it
I was just curious if the behaviour of the firmware is normal and intendet.
Good luck.
