Timestamps Incorrect
The "Print started" notification shows an estimated finish time that is incorrect.  For example:
Print Started timestamp (in bold on top right of notification) shows: 17 Nov 2019 at 16:31:23 (which is correct).
The estimated finish time in the notification body shows: Sun, 17 Nov 2019 06:50:42. (which is incorrect).
The actual finish time shows: 17 Nov 2019 at 17:30:15 (with a printing time of 0:58:52).
I would have expected the estimated finish time to show around 17:45 for this print.
  • The times come from host software, so important question is which host software did you use?
    Also in which message type did this happen? Start or progress?
  • I run Repetier-Server Pro 0.92.3 on a Raspberry Pi.  I understand now, the Pi timezone must not be local.  Is there a way to display and change the timezone?
    Thanks.
  • Server uses it's own time zone. If you use our pi image go to glabal settings->wlan->time there you can change the time zone to yours. In all other cases login using ssh and run sudo rpi-config to change time zone.
