Printing gets slow and choppy after several prints
2»
  • edited July 2015
    @Repetier if the G4 pause command is there i did not add it. as i have told you, the code works well on the 1.0.6 Repetier but on the 1.5.2/1.5.3
    the slic3r is the same when it fails and when it work well. slic3r 1.1.7.
    So how will Repetier affect the result, is Repetier adding them?
    but moreover. On this pauses there is no pause G4 command present.
    N98 *
    N169 *
    N630 *
    N991 *
    N1090 *
    < 13:30:42.558 : N97 G1 X62.384 Y68.53 E50.54897 F1500 *31
    > 13:30:42.668 : ok T:239.8 /240.0 B:90.6 /91.0 T0:239.8 /240.0 @:59 B@:127
    < 13:30:42.668 : N98 G1 X62.994 Y68.073 E50.63659 *67
    > 13:30:51.678 : ok
    > 13:30:51.694 : ok
    > 13:30:51.694 : ok
    < 13:30:51.694 : N99 M117 ETE 3h 57m 13s *37
    < 13:31:09.960 : N168 G4 P15 *118
    > 13:31:09.976 : ok
    < 13:31:09.976 : N169 G1 X158.882 Y94.688 E3.07506 *126
    > 13:31:10.210 : ok
    > 13:31:10.210 : ok
    < 13:31:10.210 : N170 G1 X159.726 Y94.97 E3.17733 *75
    < 13:31:30.188 : N630 G1 X99.445 Y125.121 E45.20335 F1500 *34
    > 13:31:31.114 : ok
    > 13:31:31.114 : ok
    < 13:31:31.114 : N632 G1 X99.282 Y124.305 E45.29899 *78
    < 13:31:46.981 : N990 G4 P326 *74
    > 13:31:47.027 : ok
    < 13:31:47.027 : N991 M117 ETE 3h 56m 24s *17
    > 13:31:47.948 : ok
    > 13:31:47.948 : ok
    < 13:31:47.948 : N992 G1 X115.399 Y120.833 E28.2017 F1500 *33
    < 13:31:51.899 : N1090 G1 X148.88 Y142.01 E5.82055 F1500 *28
    > 13:31:52.946 : ok
    < 13:31:52.946 : N1091 M117 ETE 3h 56m 20s *45
    > 13:31:52.946 : ok
    > 13:31:52.946 : ok
    < 13:31:52.946 : N1093 G1 X149.656 Y141.234 E5.94662 *123
  • Discard the last part i have notice the G4 commands,
    the question is still there,  on repetier 1.0.6 the printer does not pause/wait.
    as soon as the repetier 1.5.2/1.5.3 the printer pause/wait,
    same slic3r.
