Autobed Leveling Issue/Behavior
Hello,
i have a strange behavior which i cannot solve for quite a while now. I've searched the forum and internet but did not find a solution, so i ended up here. Hopefully i've posted in the correct subforum.
I'am running a Delta at currently 0.92.9 and i want to update my machine to the lastest FW Version.
I'am using a 3 point FSR system underneath the bed that works flawless with 0.92.9 (see attached config.h). When i use G32 the printer homes to his max.Endstops then lowers the Nozzle about 5mm over the bed and then triggering the FSR and i get an almost even bed. Rest is done by dist. correction. Also Single Probing via G30 works.
When i update to 1.0.3 (or anything between 0.92.9 and 1.0.3) the printer works just fine up to that point when i start ABL. Printer homes once then the effector goes down ~50mm above the bed, then homes again, go down once again and begin the Leveling routine. When the Nozzle triggers the FSR it moves up a bit an i get an error. No matter if G32 or G30.
(z-probe did not untrigger on repetitive measurement - maybe you need to increase distance!)
I switch back to 0.92.9 and it works.
I've used the same settings for both Versions and i did not change anything on the printer. I've also played around with heights (Sensing Distance, Z-height and so an) if maybe i've some errors in my math but still not working.
Maybe i've just overlooked something. If you need additional information please let me know.
Thanks in advance.
Gruesse aus Oesterreich,
Mfg,
Gerald
#define Z_PROBE_SWITCHING_DISTANCE 0
so it will stay with triggered sensor. That would be one problem.
The odd thing is you have
#define Z_PROBE_REPETITIONS 1
and when I look into current version 1.0.4dev you would not go into the repeated mode where that message is generated.
So please increase first Z_PROBE_SWITCHING_DISTANCE and update to dev version. That is the last stable one and where I checked the code. Just did not have time to replace 1.0.3 officially with it. Now the problem should be gone.
should be
You might need to set
#define Z_PROBE_DELAY 200
depending on how long the sensors keep the signal high after unloading. Especially these electronic sensors sometimes hold signal for a few ms so reading directly afterwards might still show wrong signal.
If it does not work do a G30 in middle and describe what happens exactly. Does it go up, does it do repeats.
