Touch UI: Heated Chamber Temp
Hello,
i am using Repetierserver and a 5" touchscreen with the TouchUI of Repetierserver. The nozzle and heatbed temperatures are shown in the top bar, but the recently added chamber temperature is not listed. At the webinterface on pc it shows up. Restarted the server multiple times.
How can i fix that?
Thank you!
  • That happens if I do not have printers with heated chambers:-) It is not programmed to appear, so no error on your side. Will add it on wide screens for next update.
    But in print status it should be visible if I read the code right.
  • Yes it is visible in Printstatus and and also in the temperature overview.
    Thank you!!
