Touch UI: Heated Chamber Temp
i am using Repetierserver and a 5" touchscreen with the TouchUI of Repetierserver. The nozzle and heatbed temperatures are shown in the top bar, but the recently added chamber temperature is not listed. At the webinterface on pc it shows up. Restarted the server multiple times.
How can i fix that?
Thank you!
How can i fix that?
Thank you!
But in print status it should be visible if I read the code right.
Thank you!!
