z-axis moves up forever
i have a Da Vinci 1.0a running repetier 0.92.
i can move my xyz axis manually perfectly fine but when i home them the x and y work normally but the z axis just keeps moving upwards and only stops when i am forced to shut off the printer. i have set the home pos of the z axis to many spots but it is the same each time. can anybody help with this?
Check also M119 to see where your endstop is. If you have min endstop use -1 otherwise 1. If it moves in wrong direction invert motor direction, not homing direction.
