z-axis moves up forever
i have a Da Vinci 1.0a running repetier 0.92.
i can move my xyz axis manually perfectly fine but when i home them the x and y work normally but the z axis just keeps moving upwards and only stops when i am forced to shut off the printer. i have set the home pos of the z axis to many spots but it is the same each time. can anybody help with this?
  • There is only one spot to change homing direction
    // Sets direction of endstops when homing; 1=MAX, -1=MIN
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR 1
    Check also M119 to see where your endstop is. If you have min endstop use -1 otherwise 1. If it moves in wrong direction invert motor direction, not homing direction.
  • after a bit more playing around i have found out the the z endstop is not being detected at all. the detector should be working fine because i only changed to repetier a few days ago and it was working beforehand, even if i block the optics with a metal ruler it still says that there is nothing in the way. the x and y endstops are both working correctly, so it is only the z axis. I am quite new to repetier so there is probably something i overlooked.
  • If it does not work any more it is probably wrong pin number or pullup is set wrong.
  • i messed about with pull ups and it didn't fix anything. all i need to do now is change the pin number but i have no idea where to find this and what to change it to. once again, i am new to this program so im sorry if this is super simple stuff
  • Normally you use the symbolic name which matches then the board pin names. Some boards just have 3 pins for xyz min so you have to use Z_MIN_PIN also if you use it for z max as there is no other available. Others have min and max and you just need to check where it is conncted.
  • What controller board are you using and what socket is the Z endstop connected too ?
