Repetier Server temp graph explanation
On the temperature graphs, what do the percentages on the right and the solid light green area on the bottom represent?
Thanks,
--Colin
  • The light green solid area is output power of extruder and matches to the right y axis. So 100% means extruder is using 100% power to heat.
  • Thanks.  That's very interesting.  I don't think I've ever seen that represented before.
