Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
Extruder & Bed
Y-axis homing
tomasby
August 2019
edited August 2019
in
Extruder & Bed
Using Repetier firmware 0.91, if I want to move the Y-axis homing position 7mm towards the front edge of the bed then I send these commands:
M206 Y-7
M500
Is this correct?
Repetier
August 2019
No, M206 sets eeprom values with different syntax. Better use eeprom editor in repetier-server or host to change y min value.
tomasby
August 2019
The eeprom editor does not work. I posted another thread about that. Could you tell me the correct M-command?
Sign In
or
Register
to comment.
