Radds 1.6 on board micro SD usage?
Hi guys,
Does anyone know how to get the Micro SD slot to work on the RADDS 1.6 board?
Everytime I plug in a SD it tries to load it but says it failed. I tried Fat32, fat and exfat formats.
All of them don't work.
I don't have a LCD screen, it's running with octoprint but I want to use an SD.
Thanks in common.
Dennis
  • Slot should work when you have no display selected. Then it uses default sd ss pin which is configured to be the one on the board. file system is vfat32. Sd card must support spi interface. Not sure what the maximum supported size is. Try dev version to use latest sdfat library.
    Thanks, for me the screen was enabled by default. How can I disable it again so the sd will work?
  • Select no display in config tool or set feature controller to 0 i think.
  • phamyen said:
    Thanks for sharing this marvelous post. I m very pleased to read this article.
    happy room
    Dude, no.. just no
