Printer Radius in Repetier 2.1.3
When doing the endstop adjustments during the printer radius calibration for my Rostock MAX v2, which value exactly do I bump 0.5mm in Repetier 2.1.3 eeprom
Is it the:
-horizontal rod radius at (0,0) OR (i currently have this as a horizontal distance measured with a tape measure from rod pin to pin after a G28 command)
-max printable radius
AND, does that number have to live somewhere else as well, like the printer settings too?
Thanks in advance.
Is it the:
Thanks in advance.
horizontal rod radius at (0,0) is what you modify during calibration. This is a firmware only variable. No need to tell anyone.
