Can you control the M3D ProMega with Repetier Server?
Hi
Does anyone know if it is possible to control the M3D Promega with Repetier Server and if it is, how to do it?
Andrew
Andrew
You can try the free version if you already have the printer.
Thanks for the quick reply.
It says it uses Open Duet 3D printer control board, source electronics, firmware and software
Andrew
Tools like nmap can scan a ip for all ports, but if it is not the default telnet port 23 it is probably not activated in firmware config.
