Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
General
fan PWM frequency
1
Bender2k
April 2017
edited April 2017
Yes! I did no print until now, but 244Hz makes PWM usable with my pump !
The pump starts with S50 and i have good flow between S100 to S255.
Maybe 500 would be even better, but also with 244 the "pulsing" is gone, so i can use it.
THANK YOU !
venkel
April 2017
News: a 220uF capacitor works for 3 fans in parallel.
Scope image is quite rough and strange, but the fans start from 15%.
elidor
June 2019
Hi
yes 2 years i know , i guess for other new user ....
my system powered with 24 volt , my fan is 12 volt 25 x 25 x 10 mm .
i have added to my setup io PWM card , and then the fan could on do on or off .
changed the fan control to PWM .
problem solved
1
Sign In
or
Register
to comment.
problem solved
