slic3r postprocessors in Repetier Host
Hi!
Im trying to set my MakerBot Replicator on Repetier Host. I know that there are a many problem to control bot via USB, but I need just generate SD-card code. My way is using slic3r slicer with post processor GPX for converting GCODE to X3G. It is working good, when I use standalone slic3r without Repetier. But I want to use Repetier GUI and thus have a problem...
When I make slice with slic3r using Repetier, I get GCODE and Repetier goes to the next step (gcode editor) missing postprocessing operations described in slic3r. So I need to start GPX-postprocessor self.
How I can see, Repetier create temprory composition.gcode file in own workpath. Can I set the file name and directory to store this temprory file?
