Z axis jerky only driver gets very hot X Y are ok
Hello,
I have problems with the correct control of the motors of the Z axis, the engine does not rotate or only minimally and the driver gets very hot. Same use of the same configuration with the X axis and the Y axis show no problems. The subject search for similar description showed me nothing useful.
My data:
- MKS Gen 1.4 DRV8825
- Repetier Firmware 1.0.3
What I have tried so far:
- bought used motherboard with Marlin firmware - works
- Motors changed
- Driver changed
- Steps changed per millimeter
- Acceleration of the Z axis reduced
My data:
- Motors changed
- Driver changed
Z axis are always enabled normally to hold position. So temperature depends on driver and current defined. Should have a cooler and best is a fan on driver also for other drivers to keep them cool.
If it sounds like loosing steps try jerk 0.1 and acceleration 50. Especially z can not accelerate or start with high speeds without loosing steps, so this is also essential.
As I said also extruder 1 can print on the left side extruder 2 can not and switching extruder in that region would crash it into the end stop. So firmware does not allow that area after homing, also you can still move to it after sending G1 S0 to disable region check. But homing will still continue to be save.
