CPU temp raspberryPI
Can you add CPU temp for raspi and CPU load? And may be other monitoring for raspi and other miniPC.
  • I think that it need do like in octoprint server. Will be good.
  • Have added it to my todos but it has no high priority as it is not print or quality related.
    Ok i will wait it! Thx! You can add an other option for monitoring miniPC!
  • If I do it you have to write a program to return values which are then showed in a table. So it would work on all computers if the script is present.
