Reset (erase) the bedmap?
Is there a way to remove all bedmap information (from the G32 and G33 commands)?
I changed the built-tak on the bed and now it seems i cannot get the first layer to be consistent across the bed (some places are too high and others too low).
I leveled the bed, reset the offset so that after homing, i send a g1 z39.85 (the height of my reference block) and the block just fits under the hot end, re-ran a g32 s2 and a g33, but the bed map still seems to not work correct. i would like to removed everything that is stored there and restart that process clean.
