Calling External Commands Return Value
Is it possible to get a return value or string from stdout/stderr and display it using the "Calling External Commands" feature?
I am using Adafruit_Python_DHT to read a DHT22 sensor connected to my Pi running Repetier-Server. I have written a script that prints the value and made it available as an external command in Repetier Server. The command runs ok, but I don't know if I can see stdout/stderr from within the Repetier Server web interface. Is it possible to see or route the output so it is visible in the web interface?
Thanks.
Thanks.
For now I have made my script trigger an IFTTT Webhooks event to notify me of the temperature and humidity whenever I run the external command.
