Customization: Touch Gui on RPi 7"
So I am ready to try to whack out all the printing functions in my touch GUI as I use this for the MPCNC.
I am following the https://www.repetier-server.com/printer-touchscreen-customization/ tutorial, and made a MPCNC folder along side the front/front2 folders that were there. Copied the "lua" and "www" folders from "front" and then modified the
to aim chromium at the new directory. But now my touch screen boots into text login mode, rather than auto logging in to my touch gui?
I changed it back to front and no avail, still stops at the login screen.
I am about to go through the tutorial for auto login to see if I can find what else may have broken.. Any thoughts?
Nick
/home/pi/.config/openbox/autostart
Nick
Now I can rip out lightdm and it still works.. so I just broke the auto-login for CLI somehow.
Only when I try to reference my MPCNC folder created by that tutorial, it says my app.html can't be displayed. :-(
Are those direction up to date with the latest Repetier Image?
Nick
The instructions you reference are for the outdated touch gui. Current version is here:
https://www.repetier-server.com/customizing-printer-frontend/
is for the current gui.
And do not forget to tell server where your shadow folder is positioned, so it uses your files.
