No EEPROM reading on Host V. 2.0
Hi, I tried new version of Host on my Linux mint system but i can't read eeprom. On mega2560+ramps "Firmware eeprom configuration" in Config menù is not enabled. On arduino due+smart ramps instead menù is enabled, after click it open eeprom window, but is empty.
I tested 3 printer with same result. on v. 1.6.2 is everithings ok.
I have the same problem. I am going back to 1.6.
They should check the SW before releasing it on all platforms. That means Linux also.
Besides, the new layout is a catastrophe. No visibility at all.
M115 response in arduino mega...
Cap:PROGRESS:1
Cap:AUTOREPORT_TEMP:1
Cap:EEPROM:0
in arduino due...with also DEV version
Cap:EEPROM:1
It's enough i think.
P.S.
The eeprom window on arduino due, is not with empty fields, it is without text fields, is totally gray.
like this...
https://app.box.com/s/6r1scw1g39tlh09p2d7pn7bjzsseo4m1
Have the same problem
V2.1.3
Marlin 1.1.9
What does it report in Cap:EEPROM at startup/M115?
