Show what COM ports are being used during adding a new printer
This is a minor inconvenience when installing a new printer into RS, but could you make it show what ports are being used in it, as in showing what printers are already connected to prevent mixing the ports up and causing issues? Thanks!
For webcams you mean the dropdown I guess. Will see. But it is also ok to use it several times and I do not want users to think it would be an error to select them when being red. Will think about it.
