Idea to select printers from the touchscreen.
I don't know if it is possible but ability to swipe the touch screen left or right would be a slick method to toggle between multiple printers.  This functionality would be similar to switching between desktops on an Android phone.
  • Interesting idea. Will test if it is doable. Amin problem is that not all screens are possible for all printers. Think of console which works only on active printers. But I like the ability to quickly switch between printers. Or a left swipe shows printers for selection. But then you are on a different screen. So swiping through them might still be best solution.
