LASER ON/OFF issue
Hi, Still struggling with laser.
When manually moving laser head with G1 laser is on
When manually moving laser head with G0 laser is on
What i did.
* replaced arduino mega
* tried older firmware
* tried older version repetier host
* assigned different pin for laser TTL output, laser on when pin is high
* erased eeprom from arduino multiple times before uploading new firmware
* deleted directories before installing new firmware/software
* delete all repetier files in c:\users\my name\local
* ran CCleaner to clean up my reg file
even after all these steps no improvement.
Still when I start repetier host a list of flies I printed shows up ??
I want to install everything from scratch, maybe the only solution?
How to delete all files from repetier host, server, eeprom, registry etc. zo I can start a complete clean installation
thanks
  • Don't do all the reinstalls. It is in firmware or the gcode you send or a combination.
    My problem is that I'm too busy to test myself at the moment.
    You could test without M3 and only use increasing E values where you want to laser. That is the second mode to operate. Or you add some print comments in Commands.cpp where G0/G1 is parsed. You will see it contains the test for laser on/off which in some cases fail, so a variable it depends on seems to be initialized wrong or get overwritten unexpectedly.
    I am not a programmer so this is abracadabra for me.
    For now I can use software I found which uses M3 and M5 and is working.
    I's rather use the right way; repetier plugin for inkscape.
    Since your're too busy I just wait this issue to be solved in the future.
    One last question for now.
    Where is the list of printed models located that show up when starting repetier?
    Thnks
  • On the sd card in your printer. Host fetches them at connection start.
  • Suggestion for the repetier plugin for inkscape.
    Add the possibility to switch laser on/off with M3 and m5 command instead of the G0/G1 as it is now.
