Server to Server Communication VIA LAN for Alternative Comunication
I have 2 PI's
both connected to network Wireless
Question if I plug a Lan Cable into the Lan Port of Each will the communicate across the lan to to help Process Renderings ect or will they only use the Reconfigured WiFi ?
Or would they Have to connected to network by by Lan
I have Hi Network Trafic on my Network due to IP Cameras and would like to be able to Isolate the PI to PI Connection if Possable
It would Be nice to Rack a few Pies on a small 5 port switch as well if running more Printers
Do not understand why you need to connect to 2 PIs? Outsourcing slow operations to an identical device is not making it faster. The idea to outsource renderings was that the "slave" server runs e.g. on a normal pc and hence is much faster.
