Printer randomly disconnects and wont reconnect unless I delete and add it again
Hi
I have a Prusa mk3s and a Formbot Raptor 1.0 on my Pi 3b. The Raptor randomly disconnects and when trying to activate, it becomes green for a split second, then disconnects again. I have to delete it in the GUI and add it again for it to work again. The Prusa keeps on going and going. Ive swapped USB ports, also USB cables. Still random disconnects on the Raptor.
If you can work for a while and then it disconnects it is often a hardware issue. Deleting in gui should not be necessary. Unplug usb and reinsert normally works as it resets usb driver. If it is on the printer usb stack side you must disconnect and unpower printer. Otherwise a disable and enable in server will trigger a reconnect that solves problems sometimes. Is a bit like new creating the printer.
On ssh console try
sudo dmesg
and see if you see many undervoltage messages. Often bad power unit is source for connection problems, also some will even work with light undervoltage. It might also depend on the usb counter part on the printer board. Do not think it is baud rate related, but it's worth a try.
