Extruder Offset in Deltas
Hi, i'm trying to set an extruder offset in my delta printer with 0.92 firmware and i'm puzzled about the extruder offset in the configuration.h
In che comment the parameters such as
#define EXT0_X_OFFSET
Are defined in steps, but for a delta printer there is no direct rlation between steps and mm therfore i would like to know how should i set the OFFETS, i've tryed tu put steps but i'm quite out with it.
Thanks.
  • It uses Z resolution for steps, whcih is th eonly steps for motion used anyway for deltas. So if you there have 80 just multiply mm offset with that value.
  • Many thanks !
