Moving Manual Z in FW 1.0.3
Hi yesterday I made the upgrade to FW 1.0.3 from 0.92.9
The upgrade was beacause I need G33 working properly without Zmax switch  so
I am using Zprobe like z min end stop mapped to z min switch.
I have  read everything and this It´s working ok.
I have seen 3 problems that in versión 0,92.9 i haven.t.
1)      Problem  I run  G32 S2 5x5 grid  inside repetier host. In the middle of routine I press stop panic button (sorry I dont remember the true name). At this situation I can´t move Z axis to down only for Up. How can move manual the Z axis. I can´t homing beacause X axis is closed  Z=150mm.
In versión 0,92,9 i can move Z axis in manual mode. I had to make a downgrade in order to move the Z axis and avoid the crash in this situation.
2)      I want put and dialGauge in extruder. I need up Z axis but I can,t home i can move  manual . In new versión this doesnt work
3)      My method of calculate Z probe height is. Write in eprom Z probe height =0. Do homing al axis.  G92 Z30 and manual going to down until NOzzle tip is 0,1mm from the bed. So z probe height = 30-down distance.  This in 0.92.9 it´s working.
Surely is a problem of config, perhaps if I mark  extruder is zprobe or Always_check_endstop the new versión Will work in manual mode as old.
The config.h was from 0.92.9 loaded in configuration tool 1.0.3. Only have added the trick for z-min endstop  switch and z probe was the same and homing order explained in other threads.
Thanks in Advanced
Detectar idiomaAfrikáansAlbanésAlemánAmháricoÁrabeArmenioAzeríBengalíBielorrusoBirmanoBosnioBúlgaroCamboyanoCanarésCatalánCebuanoChecoChichewaChino simpChino tradCincalésCoreanoCorsoCriollo haitianoCroataDanésEslovacoEslovenoEspañolEsperantoEstonioEuskeraFinlandésFrancésFrisioGaélico escocésGalésGallegoGeorgianoGriegoGujaratiHausaHawaianoHebreoHindiHmongHolandésHúngaroIgboIndonesioInglésIrlandésIslandésItalianoJaponésJavanésKazajoKirguísKurdoLaoLatínLetónLituanoLuxemburguésMacedonioMalayalamMalayoMalgacheMaltésMaoríMaratíMongolNepalíNoruegoPanyabíPastúnPersaPolacoPortuguésRumanoRusoSamoanoSerbioSesotoShonaSindhiSomalíSuajiliSuecoSundanésTagaloTailandésTamilTayikoTeluguTurcoUcranianoUrduUzbecoVietnamitaXhosaYidisYorubaZulú
La función de sonido está limitada a 200 caracteres
  • 1) did not understand why you can not home. In 1.0.x there is a target position check to avoid illegal moves. At startup z=0 is assumed which is also lower limit, so you can not move below.
    G1 S1
    would disable target position check.
    2) G1 S1 as well.
    3) Guess same as 1 and 2.
  • Correct.
    I run G92 Z30 after G1 S1 and the FW worked like 0.92.9. I can down the z axis suppose the same apply to x axis and y.
    Where is target position check via web configuration? or is possible via G1 S1 command only
    Thanks a lot of this behavour was making crazy
    Another question I tried 1.0.4 develop in order to resolve the earlier trouble when I have compiled version show a message of "Low memory disponibility" so is there any part of FW i can remove in order to avoid the message,
    I have not display so I cant remove languajes.
    Thanks a lot of for your FW and support
  • There is no option for this. You can put it in start script if you want it always active.
    If you have no display ignore the message. Test seems not to check that case. If you select a display you could remove languages to stop the message and then disable display again.
  • G
    M
    T
    Y
  • batonio said:
    G
    M
    T
    Y
    Thanks a lot of.
    So for your information I have tried version 1.0.4 dev and with automatic leveling movement is very rough. The same config.h file with version 1.0.3 and movement is soft and normal.
    Best Regards
    G
    M
    T
    Y
