Homeassistant integration
I use Homeassistant to track the status of several sensors at home. I would like to integrate repetier into the homeassistant to be allowed to see the print status with my home data or even to start or stop prints. There is an octoprint component right now that works with homeassistant https://www.home-assistant.io/components/sensor.octoprint/, so it should be possible. If not can somebody give some ideas about how to do it?. I'm also working on send and receive MQTT commands with the server to be allowed to turn on and off the printers from homeassistant, it will be nice to have an mqtt configuration section on repetier server UI.
Thank you.
Thank you.
Perhaps I'd need a few beta testers before going public. I'd recon I have the platform ready for testing within a few days.
From Home Assistant v0.94 the Repetier platform are in the official Home Assistant codebase. Currently only as a bunch of sensors, but I have plans to make some controls available too at a later stage.
I have an incomplete spinal cord injury and fortunately have retained most my motor function and sensation, but I volunteer at a resort for people living with spinal cord injury that often have little to no hand function.
Recently I have helped to introduce 3D printing as both a tool for the resort and activity for guests. home automation makes life for people living with spinal cord injury better through allowing them to be more independent. People with with SCI rely heavily on carers for almost everything so every bit of control given back to them makes their life more meaningful.
Just my 2 cents, Love your work.
