Gcode purge line before print!
I am fairly new to 3d printing but have picked up quite a bit! I am currently using Repetier Host 2.1.3 with Slic3r PE 1.40.1+win64, My question is: where can I put a purge line Gcode so it purges about 60MM before it prints? I have tried the start code but thats to early! Will I have to paste it into every Gcode before printing?
Or you just add a skirt that has a minimum length, that is the slicer solution to add it directly and close to the print.
Home before or after just like you want. If it is not in start gcode slic3r will add it for you after it, so solution is to add it on your own.
