SDCARDDETECT
I apologize if there is already a forum on this but I couldn't find it. I am trying to reflash my Monoprice Select V2 but when I go to compile the firmware I get an error with my SDCARDDETECT.
Error message: Arduino: 1.8.8 (Windows 10), Board: "Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
In file included from sketch\Repetier.h:574:0,
                 from sketch\BedLeveling.cpp:107:
                 from sketch\SdFat.cpp:20:
sketch\ui.h:865:0: warning: "SDCARDDETECT" redefined
 #define SDCARDDETECT          -1
sketch\ui.h:513:0: note: this is the location of the previous definition
 #define SDCARDDETECT 49
C:\Users\SAMRAD~1\AppData\Local\Temp\ccw5ZghK.ltrans7.ltrans.o: In function `setTimer(unsigned long)':
sketch/HAL.cpp:662: undefined reference to `stepperWait'
C:\Users\SAMRAD~1\AppData\Local\Temp\ccw5ZghK.ltrans7.ltrans.o:sketch/HAL.cpp:662: more undefined references to `stepperWait' follow
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Sanguino.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
  • No, sdcarddetect is not the problem. Check HAL.cpp line 662 and replace it with this
    volatile long __attribute__((used)) stepperWait = 0;
    it seems this solution works better. Compiler optimized the variable away.
