Cura 3.6.0
in CuraEngine
Having set up Repetier host and server on the Pi I find I cannot slice with Cura 3.6.0!
Best I can do is to run Cura from within F360, slice, save gcode to disk and then load the file to Repetier Host for printing.
Am I missing something? Is this likely to change in the near future?
However, from a user's perspective, it would be quite sufficient if F360 (or other design tool) could launch Repetier host with the .stl output. Repetier host would in turn launch Cura with the .stl file. When user finishes the Cura save would be captured by Repetier. i..e. passing the files between the apps without actual integration.
No big deal, works fine now, just a nice to have.
