Raspi WIFI not connecting to home network
Raspi 3B+ has SD card with latest server. It shows under Wireless Internet Connections as RepetierServer.
I can connect and go to the access point at 10.10.10.1 and see dashboard. From WLAN tab I can see my home router and can select it and enter password, save and connect.
The connection to access point is dropped but server does not show in the router's list of connected devices. It then reappears as the access point.
I tried power off and both PSK and PSK2 for security. Router is setup:
Security mode: WPA-Personal
Auth Mode: Auto (WPA PSK or WPA PSK2)
Encrypt Mode: AES
Must be something really dumb but I don't see it. Thanks
Encrypt Mode: AES
sudo service RepetierServer stop
sudo /usr/local/Repetier-Setup/bin/manageWifiAccess connectPW "yourssid" "yourpassword"
now see if wlan connects if command returns OK.
iwconfig
after that start server again
sudo service RepetierServer start
that time you give your network all the time it needs for first connect. Have modified it for next update a bit. Anyhow if it works it should automatically reconnect form now on after reboot.
