How is setting up an Always-doing an automatic-bed-leveling everytime prior the printing started?
I am imagining, everytime I power on the printer, start the host, load the STL, slice it and when I click 'start printing', it is always running the autobed leveling prior printing the object.
Is it possible? (Should I add few command gcode on the prefix?)
And what is the minimum requirement that the printer has to set before I could use this prefix gcode?
Please let me know those prefix commands to set on the slicer program. Thank you.
"Just write all steps you would do into the start gcode of the host"
Could you please help me to list all those gcode steps? I really appreciate it.
Am I correct? (I am not certain yet). Please help.
and then when start the printing, as I have below for the 'start g-code' that is going to always running auto calibration:
I am thinking that G29 (could be more than 3 probing) is more superior than G32 (only 3 points probing) and if I run G29, I do not have to run G32 prior or after. Is this a correct thinking?
to get the most Z error correction?
