Detecting MK3 Error messages
Last night I had a failed print, that caused these messages to show in the log:
< 3:53:43.475: N382699 G1 X74.034 Y107.238 E0.10559
> 3:53:43.504: ok
< 3:53:43.504: N382700 G1 X73.975 Y106.646 E0.02079
> 3:53:43.590: ok
< 3:53:43.590: N382701 G1 X71.802 Y108.819 E0.10742
> 3:53:43.618: ok
< 3:53:43.618: N382702 G1 X71.735 Y108.431 E0.01377
> 3:53:43.639: // action:pause
> 3:53:43.643: Extruder fan speed is lower then expected
> 3:53:43.803: ok
> 3:53:50.521: // action:pause
> 3:53:50.525: Extruder fan speed is lower then expected
> 3:53:53.167: fsensor_autoload_check_start - autoload ENABLED
> 3:53:57.402: // action:pause
> 3:53:57.406: Extruder fan speed is lower then expected
> 3:54:04.284: // action:pause
> 3:54:04.288: Extruder fan speed is lower then expected
> 3:54:11.165: // action:pause
> 3:54:11.169: Extruder fan speed is lower then expected
The messages continued for a half hour, then I got this:
> 4:04:39.213: Extruder fan speed is lower then expected
> 4:23:55.094: echo:busy: paused for user
> 4:23:57.122: echo:busy: paused for user
Until I manually intervened. I did eventually get a push notification that the print had failed, but it happened much later than the actual error.
Is there a way I can add filters that can be trapped to send push notifications? I thought I read something about that, but can't find that info this morning. I'd like to add traps for filament sensor, fan failure, and other common errors I see.
I don't mind working in the code and submitting a patch, if you could point me to the correct file.
Thank you-
> 4:04:32.328: // action:pause
> 4:04:32.331: Extruder fan speed is lower then expected
> 4:04:39.209: // action:pause
// action:pause
tells server to stop sending gcode.
is a hint that firmware is still waiting for user interaction. Once you fix the problem on your printer and tell it to continue it should tell server
// action:resume
and server would continue to print. You need to fix the problem using the printers lcd where the printer waits for user interaction.
