Multiple Pi's: possible to view all machines from each Pi in one Server instance?
I currently have 6 printers and 2 webcams split evenly across two Pi 3's. One of the reasons I didn't like Octopi is having to maintain separate instances. Just bought the Pro version of Server and hoping there is a way to view all my printers on one Server instance vs two? TIA
Also, Have not be able to get remote access setup. One of the biggest reasons I moved to Repetier is because I want to be able to access and issue commands to the printers when I'm at the day job.
If I can get the multiple Server instances combined into one, remote access, and both cameras working I will be thrilled. Otherwise... I may be looking at a refund and switching back to Octopi.
Really hope this is a more "premium" solution for my print shop vs Octopi which is free and easy to use, but lacking in some features that RepServer lists (namely the above three).
To access remotely from outside you need either a VPN solution which is best solution for security, or enter port forwarding in your router and add yourself to a dynamic name server solution like duckdns to know your ip at any time.
Regarding pi cams - first test if linux sees and supports them:
/usr/bin/vcgencmd get_camera
> supported=1 detected=1
If not you have most likely connected the ribbon cable the wrong way around. Only one side has contacts!pi@FelixWhite:~ $ ps aux | grep mjpg
root 654 2.1 0.2 108452 2512 ? Sl 2018 787:57 /usr/local/bin/mjpg_streamer -i /usr/local/lib/mjpg-streamer/input_raspicam.so -fps 15 -x 640 -y 480 -quality 85 -o /usr/local/lib/mjpg-streamer/output_http.so -p 9000 -w /usr/local/share/mjpg-streamer/www -b
pi 27713 0.0 0.0 4372 552 pts/0 S+ 07:39 0:00 grep --color=auto mjpg
Should show a instance with port 9000 if using our latest image. You just need to enter that in the printer configuration. Should have a drop down offering it.
Webcam looks good as if it is running, so what did you configure in printer setup for webcam?
http://127.0.0.1:9000/?action=stream
http://127.0.0.1:9000/?action=snapshot
should be the 2 urls for pi webcam.
I may just put Pi Zero in all of my Prusa's instead of waiting for the unified interface. That way I can add more cameras with the freed up Pi 3's.
Thanks again!
