Unable to connetct to server running on localhost
I successfully installed both host and server on the same machine.
The server works regularly, connects to printer, and is accessible by the webserver.
Similarly the host works nicely, slicing properly.
But they cannot talk one another. When I try the procedure for installing the printer on the host by Repetier-server, after I put in the API code, as I try to connect, I get a "socket error". It says that there is an exception in OnOpen.
I tried everyting, unsuccessifully.
Can you help me?
