Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Server
Can i initiate auto bed leveling remotely?
Mariskay
December 2018
in
Repetier-Server
Hey there, CR10S, Marlin firmware, any way to initiate AutoBedLeveling with probe remotely from Repetier Server www? Thanks
Repetier
December 2018
Yes, just send the gcode over the console. I think marlin uses G32 for autoleveling.
Mariskay
December 2018
Ah, okay, G32 and storing the probe matrix, do you know which code does that after bed has been auto-leveled?
Mariskay
December 2018
Would be great if i could create custom buttons and put any G-code script under them in Repetier Server GUI
Repetier
December 2018
You can. Go to printer settings->G-Codes and add a quick command. That is available in control and manual control in the dropdown for gcode commands then.
For exact definition of G32 please read marlin manual.
Mariskay
December 2018
Thanks, will look into it!
MartinH
December 2018
Marlin firmware uses G29 for auto level, G32 is 'repetier'' firmware
https://reprap.org/wiki/G-code#G29:_Detailed_Z-Probe
Sign In
or
Register
to comment.
